runs funny sometimes
Old Nov 27, 2011 | 01:01 AM
pbillyi69's Avatar
Default runs funny sometimes
hi all. i have an 01' 2500 hd 4x4 with the 8.1L and the allison..... sometimes when i am accelerating hard it seems like slips and sometimes it seems like it stumbles around 4000 rpm not completely wide open but close. after the stumble the check engine lite will come on..... it throws mass air flow code.. if i dont reset the code sometimes the light goes off on its own and sometimes i have to reset it.....the truck has a k&n cold air intake a stupid throttle body spacer that im sure doesn't do a dam thing. it also has an aftermarket mass sensor.... it will seem to run fine after it reset the trouble code it just appears to be random but it is way too frequent to be normal....what should i do??
Old Nov 27, 2011 | 01:30 AM
NullHead's Avatar
Amazon Amazon
EDIT: Also, unplug the senor and see if anything improves.
Old Nov 27, 2011 | 11:36 AM
pbillyi69's Avatar
i didn't think it would even run with it unplugged
Old Nov 27, 2011 | 01:35 PM
NullHead's Avatar
There are preset values stored in the PCM to allow for MAF failure. If you unplug it, the system will run off of the preset values and calculate the air/fuel based on that. If the truck runs better, then clean the sensor and plug it back in. Be careful though, it's a delicate sensor, and do not touch the little wires inside of it. Handle it carefully and do not touch the sensor. Let the cleaner dry and then re-install.
Old Nov 30, 2011 | 12:11 AM
pbillyi69's Avatar
thanks for the suggestion. it needed to be cleaned really bad. but in doing the tests i encountered something else.... it seems to shift a lot harder when the MAF is unplugged, why would this be? also when i was driving around with the MAF unplugged it threw a code that referred to the throttle body and wouldn't run.... i was glad that i had the code reader with me so i could reset it or i would have had to be towed...
Old Nov 30, 2011 | 12:42 AM
NullHead's Avatar
Well you could have just plugged the sensor back in.
But it will shift harder, because the PCM uses some of the MAF data to help the transmission know when and how hard to shift. For example, if you're WOT, and your engine is high RPM, the transmission wont want to shift hard because of how much power the engine's putting out. The MAF also help the PCM calculate air/fuel mixtures. All of that combined makes for a very important sensor.
Old Nov 30, 2011 | 10:42 AM
pbillyi69's Avatar
thanks. i did try just plugging the sensor back in didn't matter until i reset the code for the throttle body it wouldnt go.. anyway thanks for the info...
Old Nov 30, 2011 | 11:02 AM
NullHead's Avatar
So did cleaning the sensor help fix your problem?
Old Nov 30, 2011 | 03:49 PM
pbillyi69's Avatar
it seems to have helped some im not sure if it has resolved the issue.. my check engine light hasn't come back on yet so that is a good thing. i haven't had a chance to floor it through all of the shifting yet to see if it stumbles cleaning made a difference for sure.
Old Nov 30, 2011 | 06:07 PM
pbillyi69's Avatar
okay i went and romped on my truck and cleaning the MAF fixed it for sure the pinging went away which is good since im paying 4.29 for non-methanol super. so do you have any ideas of how to turn the torque management off in my tranny? allison thank you for your help
Truenoob
May 6, 2009 08:20 PM
jafran456
Jun 3, 2008 05:45 PM
Gary
Nov 16, 2007 03:18 PM
chev.half
Jun 17, 2007 04:20 PM
blaze276
Jul 8, 2006 01:51 PM
