runs rough cold but fine after warmup
I have a 2002 Sierraa 1500 with the 4.8 engine with 120,000 miles. I have been expereancing rough idle and increase reveing when temps get below 50 degrees. After a short time and the engines warms the truck runs great.
I have replaced the air intake sensor, the coolant sensor, new fuel filter, plugs, removed and cleaned oxegen senors and cleaned the throttle body but none of these has worked. Please help. Thanks |
If you have replaced the IAT then you mean you have the replaced the whole Mass Air Sensor? When you cleaned the throttle body did you take it off or leave it on and just spray it? If you take it off you can inspect the IAC valve and lots of times it will gum up and get sticky.
Sounds like what my 97 did when the crank sensor went out.....I would check it too
Thanks for your help and will look into both suggestions
Originally Posted by michaelringo
(Post 62007)
I have replaced the air intake sensor, the coolant sensor, new fuel filter, plugs, removed and cleaned oxegen senors and cleaned the throttle body but none of these has worked. Please help. Thanks https://www.truckforums.com/forum/sh...ad.php?t=15197 |
