sensors
where would the heat sensor be on a v6 gmc 1997safari. the van will not start after it gets warm up. was told the the heat sensor could be the pro
blem. any help will be appreciated. James |
You are probably referring to the coolant temp sensor. It is usually right next to the thermostat housing.
