-   -   Silverado - Brake Lights won't shut off (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/silverado-brake-lights-wont-shut-off-16055/)
bgibson11 Mar 10, 2011 06:07 PM
I have a 2003 Silverado.. My brake lights will not shut off no matter if truck is running or not.
To temporarily keep the battery from dying, I pulled the VEH STOP fuse under the dash and it turned off the rear lamps however the third light (by the cargo lamp) will not shut off still. I opened up the fuse box under the hood and couldn't find out how to shut the 3rd light off.
Outside of pulling fuses - where does one suggest I start in fixing this? I went to work this AM and they stayed on when I parked. Came out to a dead battery.
Would like to get this fixed ASAP.
jreagan Mar 14, 2011 03:30 PM
Look for CHMSL (Center High Mount Stop Light). Same fuse for the trailer plug.
If that "fixes" the problem, then that would be the first place I'd start looking for a short from the 12v 'hot at all times' back through the stop light wires.
98Chevy Mar 28, 2011 03:41 PM
brake lights wont shut off
I also am having this problem on my 1998 silverado k1500. i recently replaced the brake booster and after finishing i realized that my brake light were still on when the truck was turned off. i was told that it might be the stop light switch on the back of the the brake pedal. so i replaced it with an acdelco part it was defective and created another problem which was i couldnt shift out of park...so i replace it again with a BWD part and my lights are still on but i can shift. i ve taken it to a mechanic and he can frigure it out either so any help would be apprecatied.:mad:
98Chevy Mar 28, 2011 03:44 PM
might need to add that all fuses are fine and the mechanic didnt find any shorts
xetaitot Jul 27, 2019 03:44 AM
For long-time drivers. The problems you often encounter in your car are really not easy. We need more experience to easily overcome small incidents. But a repairman now really needed.
