Silverado Z71 Driver Information Center Message After Installing Radio
Old Jan 19, 2011 | 07:47 PM
QCZ71's Avatar
Default Silverado Z71 Driver Information Center Message After Installing Radio
Hi, I just installed a Ham Radio in my 2004 Silverado Z71 Truck we used a fuse tap when I start the truck I get this message "battery not charging" it goes away right after I start the truck and I do have the radio off when I turn the radio on It shows about 14.5 volts so the alternator is working the fuse I'm using is for a rear window wiper which is not installed on my truck it has a 15 amp max I do have 2 15 amps fuses installed on the fuse Tap. The black ground wire is attach to a 10mm head bolt that is under the driver side aera by the OBD-II port not Any help would be appreciated
Thanks
jjump
Jan 2, 2011 09:04 AM
F15E154
Dec 31, 2010 09:42 PM
restridge
Jul 15, 2010 07:23 PM
02AmeliaChevy
May 12, 2009 04:26 PM
fshnfool
Dec 21, 2005 06:58 PM
