Need help
Old 05-28-2013, 10:56 PM
Cpt. Corndog's Avatar
Default Need help
I have a 1987 Chevy V10 4x4. I just finished installing a 4in. lift kit and the last thing I need to do is replace the factory steering arm with the drop steering arm. it connects to the drag link via ball joint and castle nut and to the knuckle via 3 7/8 in. pressure crimp nuts. I disconnected all the nuts and the drag link but still cannot seem to loosen it from the knuckle. I have soaked it in PB Blaster and heated it up with an acetylene torch while hammering around the bolts.
How in the h**l do you take the steering off? Please help! this is the last step to my lift kit. thanks, Blake!
Old 05-28-2013, 11:23 PM
Wow !!! I just took mine apart a few weeks ago, cause the rear knuckle on the drag link had too much play in it.
I loosened the castle nut off until it was at the end of the threads,
With a ball peen hammer resting evenly on the castle nut and stud I gave the small ball peen hammer a good hard swift hit with a second heavier hammer.
Old 05-28-2013, 11:27 PM
I got that part off. I need to take off the whole steering arm from the knuckle. Its the horseshoe shaped chunk of metal that turns the wheel.
Old 05-29-2013, 05:26 AM
acnas's Avatar
Pitman arm puller. Coming off the steering box right?
Old 05-29-2013, 12:27 PM
not the pitman arm. its the steering arm. it connects the drag link to the knuckle.
Old 05-29-2013, 12:31 PM
Old 05-29-2013, 09:39 PM
NullHead's Avatar
You're talking about this right?
I'd use a puller, or air hammer on the end of the stud. Heck, the pitman arm puller might just work. That or get the thing on the far right of this picture:
V10 has a full front axle, right? Not a cheesy "differential + CV axles" type deal?
Old 05-29-2013, 11:39 PM
The Drag Link attaches to that U shaped component you posted a picture of above and it (Drag Link) attaches to the pitman arm which inturn attaches to the steering box.
As I posted earlier. You can back off the castle nut then use a hammer.
Or use a knuckle puller.
Old 05-30-2013, 04:59 PM
acnas's Avatar
Sorry! I was thinking s10 setup for some reason??
Old 05-30-2013, 05:06 PM
acnas's Avatar
Dawe
11-29-2011 03:05 PM
joebug1956
02-18-2009 10:03 AM
Quick Reply: Need help
