@gmcsierra fan thats what i was thinking also after some one suggested make a mark on the tire in a post above
maybe that would work maybe not |
I would tend to agree with you, which is what I was basically saying, but when we tried it with my dad's 90 model chevy; it was hard to figure out. We were trying to determin if it had 373s or 342s. It was so close it took us numerous tries. Ended up using the vin number since the rear end had never been gone into. Tried it and see.
lol i know according to my glove box numbers i have the 3.42 gearing in the rear end but i havent looked to see if its been opened up before or not
as i want to try to figure it out so i know because its driving me crazy not knowing anyway how did you come across finding out what it was |
I got mine from a web site that was able to tell me everything about my truck by the vin number. It had all the manufacturer's codes and was able to tell me every option the truck left the factory with. It also determines how many trucks of a certain year rolled at of the same factory that were identical to the one I have. It was pretty cool. I will try to find it and let you guys know.
Originally Posted by azjetfighter
(Post 68242)
also i used a website that told me everything but it said i had or have 3.42 gearing in the rear diff but i am thinking it maybe different as when i am in a slippery spot both my rear tires grab and start to spin if it was the stock 3.42 it would be a one legger and for the website there is an old old old forum on here some where that has the link thats where i found the one i went to |
It's still possible that you have 3.42 gears. Most of the trucks rolled of the line with a limited slip diff. Especially the ones with V8s and towing packages. That's why your truck isn't a one-legger
(Post 68248)
so someday i will be getting 4.10 gearing in there and also in the front as well |
Since we have thoroughly discussed gear ratios now, are there any other ideas about what could be causing my problem with higher than normal rpms? I also noticed that at 50 mph in overdrive my tach reads 1900 rpm. Also, I get better fuel mileage in stop and go city driving than I do out on the interstate. Any ideas would be greatly appreciated. Thanks
i cant really think of anything else other than maybe a trans issue or throttle problem
