Spins over but won't start
Old Jan 17, 2012 | 11:14 PM
96Z71_?_Al's Avatar
Red face Spins over but won't start
Sorry if this is a repeat question but I'm at the end of my rope and need help quick. Here's the deal, 96 Chevy Z71 Ext. cab 5.7L, parked for about a month. Truck was running fine when parked except for bogging when passing gear was kicked in. The battery went dead and I had to get a replacement key cut. Swapped the battery and now it just spins and won't even try to start. I poured a little gas into the throttle body and it would run but rough. Pulled the bed, changed the fuel pump, sock, dampener, and fuel filter. Pump comes on and getting pressure at the check valve. Tested with a gauge and only getting 10-11 psi. What am I missing? Please help.
Old Jan 17, 2012 | 11:30 PM
NullHead's Avatar
Check your fuel filter.
Old Jan 17, 2012 | 11:46 PM
96Z71_?_Al's Avatar
replaced filter already.
Old Jan 18, 2012 | 07:44 PM
Wiked's Avatar
bad fuel regulator?
faulty injectors?
Old Jan 19, 2012 | 07:41 AM
Does the security light flash in the instrument cluster? You may need to do a security relearn.
Old Jan 19, 2012 | 09:30 AM
96Z71_?_Al's Avatar
I got the fuel pump from a buddy. Turns out, I think it is for a throttle body putting out only 10-12 psi. Picking up new pump today and I will post results tonight.
Old Jan 20, 2012 | 08:48 PM
RUFFNECK4LYFE's Avatar
I think TBI's run about 15 psi. Let us know what happens.
Old Jan 20, 2012 | 10:47 PM
NullHead's Avatar
The spec for my 89 says the TBI should have 9-13 PSI and it would be considered acceptable.
Old Jan 21, 2012 | 09:54 AM
96Z71_?_Al's Avatar
Replaced the pump with the correct one from the parts house, hit the key and it fired right up. Took it for a spin, and it wont shift down into first or up out of third. Service engine light is staying on. Is it maybe a sensor? What sensor would affect the transmission shifting properly. Keep in mind it sat up for a month but the trans is new with only about 2k miles on it.
jackedupride
14
Jan 1, 2012 09:55 AM
claptonblackie
Jun 16, 2010 08:41 AM
claptonblackie
Jun 8, 2010 02:49 PM
Shed Hunter
11
Sep 2, 2009 03:10 PM
SPRCHRGDGM
Feb 25, 2007 09:55 AM
