| Dwcreech |
Jun 29, 2013 11:26 PM |
starter problems on 96 z71 with 5.7 liter
Question: my starter was starting to crank noisy. Then it wouldn't crank. The bolts had broken off and the starter came loose. I bought the truck used and I'm assuming the bolts weren't starter bolts. One of the bolt holes in the housing is cracked. The starter is good but when I try and mount it if its aligned properly the bolt holes are off. If I just bolt it up its not aligned. I've tried shimming it and can't get it shimmed properly. There are other bolt holes in the mounting housing so is there another mounting option besides an oem starter?
