-   -   Starting fluid (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/starting-fluid-12483/)
daffy427 Jan 7, 2010 12:11 PM
Starting fluid
My 98 Suburban will not start without a shot of either. After that it will restart all day long. It has 50+ lbs of fuel pressure. Anyone here got any ideas??? Thanks in advance.
RUFFNECK4LYFE Jan 7, 2010 12:26 PM
Is it pretty cold where you are at?
daffy427 Jan 12, 2010 07:29 PM
Nope...I'm in Southwest Florida.. It's been really cold the last couple weeks but this problem has been going on for a long time.. It used to be intermitten but now it's consistant.
RUFFNECK4LYFE Jan 12, 2010 10:29 PM
I work on drilling rigs where we use diesel motors and we have to use starting fluid to first start them. I remember one guy saying once you use it on them, you always have to after that. Not sure if this true for gas motors.
SlimJim Jan 13, 2010 08:36 AM
This symptom used to come up with carburetors when the bowl would leak down overnight. Once you started it and filled the bowl back up, it would start all day. I don't know of anything equivalent on FI. Prime on the pump but you have good pressure. Have you measured the pressure when it won't start or after it has been running?
