-   -   starting problems 98 gmc sierra 1500 (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/starting-problems-98-gmc-sierra-1500-a-10161/)
bpa1216 May 23, 2009 03:09 PM
After I have run my truck for a while, when I get back in to start it. It will just crank like it is not getting gas and then wait a few minutes and it will start right up.
RUFFNECK4LYFE May 23, 2009 06:59 PM
How does it idle?
bpa1216 May 24, 2009 11:46 AM
it idles fine..
Willdog Jun 4, 2009 02:52 PM
Same Problem
I am having the same problem except mine won't start. It is a random thing where out of no where it will crank over but not start. If I spray starter fluid in here, she starts til the fluid is gone. I have had it towed to the dealer and of course there it starts. They did dianostics and pressure checks and supposedly everything is good. I replace the fuel pump relay, still doesn't work. What gives?
RUFFNECK4LYFE Jun 4, 2009 06:53 PM
Someone else had a thread on silverados with the same thing and said it was his pcm grounding out or something.
vortechpower Jun 6, 2009 01:39 AM
I had the same problem, i had to replace my whole sending unit.
husqvarna8 Jan 25, 2010 05:34 AM
On a 1999 GMC Sierra... cranks over and starts for a second and dies. Replaced pump, filter, relay. Any ideas? When I disconnect battery it has started after I reconnected but then same thing again.
