Steering issue - clunking and rubbing/groaning sound
I have read a good many posts about the known issue with low-speed steering on the 1500's that manifests itself with a clunking under the hood that can be heard and felt in the steering wheel. As I understand this, the fix to this is either temporary (lube) or permanent (replace the intermediate shaft). My question is this, I have the symptoms listed above but also get a moan/rub sound in low speed turns. Does this sound like a related issue? Also, I have read that a lube on the affected part(s) will run about $90. How much should I expect to spend for the replacement of the shaft for parts/installation? Thanks...
RE: Steering issue - clunking and rubbing/groaning sound
should be covered under warranty if you still have warranty
the shaft is 90 dollars....a lube kit about 15...its not too hard to do
argon is this some thing that i can do at home? I have tons of tools and a pretty good knowledge of trucks.
