| NullHead |
Jan 30, 2012 11:41 PM |
I don't quite understand your question.
From my experience, there are two harness you'll need to install an aftermarket radio, a harness that comes with your radio, and plugs right into the back of the radio with cut wire ends on the other side, and a wiring harness that plugs into your truck's OEM radio connector.
Usually metra makes these OEM to aftermarket radio harnesses. Your job is to connect the wires from the Metra harness to the radio's harness in order for the radio/speakers to work.
