sticky throttle
Old Jul 14, 2007 | 02:36 PM
popo's Avatar
Default sticky throttle
It seems there is a hitch to the TB mod. After a reinstalled everything i noticed i had to push the accelerator harder to go initially, kinda like it is sticking closed is it possible to adjust it?
Old Jul 14, 2007 | 05:00 PM
Argon's Avatar
Default RE: sticky throttle
clean the butterfly...the gunk is hanging the butterfly
Old Jul 14, 2007 | 09:43 PM
popo's Avatar
cleaned and it runs better but i think i need to adjust the idle screw a little bit
Old Jul 14, 2007 | 11:37 PM
chevy112488's Avatar
does adjusting that screw do anything other than change the idle? i've been tinkering with mine because after i installed my tbs my truck started trying to die when idling... tightened it up a little and it fixed the problem, but now it revs to damn near 2 grand just cranking it up
Old Jul 15, 2007 | 06:41 AM
Argon's Avatar
when you turn that screw,you move the butterfly,which moves the tps as well...it will idle wildly and set codes if it gets out of range
Old Jul 15, 2007 | 10:51 AM
popo's Avatar
I moved it about a quarter turn and now it is perfect
Stan S
Nov 27, 2009 11:22 AM
bigred29067
May 24, 2008 03:14 PM
jcbst12
May 1, 2008 11:08 AM
steelfan
Dec 8, 2006 05:20 PM
nick
May 8, 2006 10:00 PM
