strange sound in trans
i jacked up truck and put on jack stands and pulled drive shaft
it sounds like noise is coming from the tail shaft i pulled the back houseing off and semms to be fine but tail shaft has some play in it how much should it have (play) |
RE: strange sound in trans
a fair amount...does the noise change when it shifts?
yes it seems to be worse in 1 and over drive
it is a squiling sound of some sort |
not good..1-4 are the same clutch...better hit the dealer or trans shop
stll shifts the same but it makes that sound do u think that it is some thing broke i side if so sould i be able to pull pan off and see some thing in the pan
i doubt it..there is a 1-4 drum thats known to break..or its bearing...i'd get it checked out...
