sub power supply
Old Jun 29, 2007 | 12:02 AM
stopspazinout's Avatar
Default sub power supply
today while driving i noticed that at each peak of bass my volt meter would drop i didnt used to have this problem. but since switching to a larger amp i am. anyways, your guys thoughts what would be better a capacitor or a optima red top battery?
Old Jun 29, 2007 | 01:15 AM
chevy1224's Avatar
Default RE: sub power supply
def. a capacitor... the red top wouldnt do what your wanting it to.
Old Jun 29, 2007 | 08:18 AM
hunt4game29's Avatar
Hey i have read somewhere that if you up your size of ground wires it will help also. But not sure if it will help this.
Old Jun 29, 2007 | 10:03 AM
sootjunkie65's Avatar
id go with a capaciter, but an optima battery wouldnt be bad either, id get a yellow top though, thats the deep cycle one.
Old Jun 29, 2007 | 10:11 AM
popo's Avatar
ditto. I had this problem when i was running under drive pulleys. the capacitor fixed it completely. a word of caution. when you get the capacitor, be sure to un hook it as well when you do any work that requires unhooking the battery. I have first hand knowledge that the capacitor can put you on your a$$ just as good as a battery can.
Old Jun 29, 2007 | 11:10 AM
DUB2420's Avatar
a capacitor only stores voltage for deep power draws then needs to recharge , it will only stop your lights from flickering or voltage to drop for the first big sub hit , then it will need to recharge it self so it will not solve youre voltage issue .. if your just running it off the battery under the hood make sure that the grounds on the battery are the same awg wire or greater than the power cable ran to the amp example : running 4 awg power cable from battery to amp and grounding amp with 4 awg but only having a coupl 8 awg battery grounds is like running 8 awg wire to the amp.. make sure all grounds in vehicle are the same awg as power supply.. also a red top will not help it is designed for deep draw startingit has a high CCA rating but not amps/hours.. the only real solution to the problem is to upgrade to a higher amp output alternator and add batterys to the system.. a battery is the biggest capacitor in the vehicl eafter all.. hop ethis helps and doesnt confuse lol
Old Jun 29, 2007 | 02:34 PM
smoke20's Avatar
Bigger alternator, and dual batt.
Old Jun 29, 2007 | 04:38 PM
im thinkin of trying a larger alternator and maybe a capacitor. it only gets bad when im stopped and its continually hitting that it drops to about 9-11volts.
Old Jun 29, 2007 | 05:06 PM
but if i choose a dual battery. how do you wire it in to be recharged?
Old Jun 29, 2007 | 11:01 PM
ok well do you think a 140 amp alternator would boost enough juice? a 200 seems like a lil bit of overkill, but then again i dont know what the stock alternator is putting out either.
