Superlift 8" Lift Kit for 2014 GMC and Chevy 1500 Series 4WD Pickups
Old Jul 9, 2014 | 10:20 AM
Superlift Suspension's Avatar
Former Sponsor
Default Superlift 8" Lift Kit for 2014 GMC and Chevy 1500 Series 4WD Pickups
Superlift 8" lift for the 2014 Chevy / GMC 1500 series platform easily runs 35" tall tires and is the kit to have if you want to avoid trimming the fenders on your new high dollar 4x4. Our 8" kit is a replacement knuckle system and was designed using factory dimensional data. Using OE data files allows us to design lift kits that mimics the original factory designed components. This aids in installment and compatibility. It also allows our engineers to design a kit that once installed not only retains your truck truck's excellent ride and handling characteristics, but one that is also compatible with GM's Stabilitrac® anti-skid system. The Superlift 8" lift will allow you to run your stock or other OE 20" and 18" wheels with 1/4" front wheel spacers. Depending on the specs, the wheel space is not needed with aftermarket wheels. Check the specs thought before purchasing as they may be needed. As with all of Superlift's products, the lift is backed by our Lifetime Warranty and Satisfaction Guarantee.
Quick Look Features of the Superlift 8" Lift Kit for 2014 GMC and Chevy 1500 Series 4WD Pickups
  • Designed using factory CAD data
  • Compatible with factory Stabilitrac® and anti-skid control features
  • Replacement cast ductile iron steering knuckles
  • High clearance, one-piece cross members, and all other load bearing bracketry, is laser cut from .25" thick plate steel
  • Front differential skid plate integrates with cross members for additional system rigidity
  • Rear cross member kicker braces further increases system rigidity
  • New front premium gas struts and Superide rear shocks
  • Rear lift via blocks and add-a-leafs
  • No front differential trimming
  • Clears 35” diameter tires without fender trimming
  • Limited Lifetime Warranty
  • 100% Satisfaction Guarantee
The 2014 1500 Series pickups come equipped with either factory steel or aluminum lower control arms, so Superlift designed specific lift kits for either application. The K942 is designed for trucks equipped with factory steel lower control arms, and the K943 is designed to work with trucks equipped with factory aluminum lower control arms . Both kits look nearly identical, so make sure you read the notes and fitment section of the product catalog page should you opt to visit our web site and order one.
This premium Superlift Suspension lift system retails for only $1399.95 – complete with shocks, and is available direct from Superlift or through one hundreds of Superlift Dealers nationwide.
To find out more about this lift system click on any of the images below. For information on this or our complete line of lift systems for GMC and Chevy trucks please visit www.superlift.com
nick_bp
Jan 8, 2014 02:54 PM
k1500j1
Mar 9, 2012 11:39 PM
JunctionBoyz
Aug 9, 2011 10:31 AM
DivotMaker
Mar 31, 2011 01:32 PM
dimmuborgir6nik6
Nov 5, 2010 07:57 AM
