Suspension Rattle?
I have hada rattle either in the front or middle driver's side of my 2002 Chevy Silverado 1500. The problem isn't the well known "steering column knock". The rattle will only happen when i go over a bump on the driver's side. I have been under the truck numerous times and can not find anything loose or anything that could be causing this. Any Ideas?
RE: Suspension Rattle?
how old are the shocks on it? could also be a worn out ball joint.
I would just turn the radio up louder and ignore it.
Look at trhose 2 "bars" under it by the oil pan..the 13mm bolts like to work loose
Shock are still original....there are 71,000 miles on the truck... I will check the bars by the oil pan
THANKS |
Let me know if it works I have the same problem statring on mine...
Hey, look... 666 posts... |
lol nice grab, but your the devil!!!!:D
MrLM7 has taken the reign of Devil from me finally, I thought I would never get that monkey off my back.
Hey jlbond,
Did you find a solution? I'm having a similar rattle in my rear-end. Thanks, Phil |
i'm having the same problem on my 06 silverado. ever figure out what the problem was?
| All times are GMT -5. The time now is 10:33 AM. |
