View Poll Results: A poll
smooth bore
18.18%
swirled bore
72.73%
extra crispy
9.09%
Voters: 11. You may not vote on this poll
which TBS should I get
Old Apr 10, 2007 | 01:23 PM
popo's Avatar
Default which TBS should I get
I went to summit and they have two transdapt TBS for my 4.3 a sooth bore and a swirled bore. Which do you think I should get and why. I couldn't find a real difference other than they said the smooth bore one doesn't whistle.
Old Apr 10, 2007 | 09:09 PM
SC_Chevy_Lover's Avatar
Default RE: which TBS should I get
It's all based on if you want that whistle sound or not. My Jet Performance is slightly swirled, but there is no whistle at all. I think Airaid is the loudest.
Old Apr 10, 2007 | 09:25 PM
BigTexasChevy's Avatar
look man i have seen the dyno differences ..as i have posted a few months ago...but the smooth bore is the best performer of the bunch. just think straight flow or a swirl?? the swirl was actually proven to slow velocity down. i mean i love the swirl, and there is such a small difference it would not matter which one you get. i like both and think either is a great decision.
Old Apr 10, 2007 | 10:20 PM
MrLM7's Avatar
They say the swirls help the air get around the bends in the intake manifold.
Old Apr 10, 2007 | 10:24 PM
the way they are made im sure they do. i just remember when i was dynoing my 03, i had a smooth bore given to me by a friend, and a Airaid swirled, and the airaid had like almost 2 hp and 2 ft lbs less. not like that would ever be noticeable, but for a minor bolt on it showed the difference.
Old Apr 10, 2007 | 11:12 PM
superddd's Avatar
I don't have a spacer on mine, but I still seem to have a whistle. It almost sounds like I have a turbo and you can only hear it when I getting higher in the RPM's. I know hunt4game has heard it. Does anyone know what could cause that?
Old Apr 11, 2007 | 01:58 AM
smoke20's Avatar
superdd - are you sure there is no air leak? That will give you a whistle.
Old Apr 11, 2007 | 02:13 AM
superddd's Avatar
Is there any easy way to find an air leak? I've never worked on one before so I don't really know what I'm looking for.
Old Apr 11, 2007 | 03:40 AM
i know an old trick my dad used back in the day, and that was spray carb cleaner all over your intake tubing, if it picks up on the idle, you have a leak, if you hear no change in tone, you are good.
Old Apr 11, 2007 | 04:08 AM
I've heard that old trick too. Check are you seals and clamps. Make sure your clamps are fasten down well. If you have a leak, what better excuse to get a CAI!!
