Temp guage
First off its a 95 sierra k1500 ext cab. short bed z71, when the truck is warming up the guage goes up to approximently 3/4 then drops back to just under halfway and goes back and fourth just over half ! if you shut the truck off for bout 5 mins the start it back up it reads 1/4 like its been off for long time but then repeats the process of going back up and coming back down ! I've changed the thermostat and cooliant still does this !
Any help would be appreaciated ! Thanks
I believe you have a temperature sender that could be the problem. The sender is screwed into the block and sends a voltage to the gauge representing the temperature of the coolant. Other than the gauge itself, I don't know of anything else it could be. Good luck.
eter4
Jan 17, 2007 03:05 AM
