-   -   throttle body spacer (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/throttle-body-spacer-4314/)
stopspazinout 08-27-2007 11:23 PM
put it on today and instantly noticed an increas in mid and high throttle very happy with the results and not to find out its a worthless piece of metal.
72charger 08-28-2007 06:59 AM
RE: throttle body spacer
Cool beans! Glad you like it man. I am lovin mine!:D
bulachip 08-28-2007 12:33 PM
Is it difficult to install? Would it work on a 305?
stopspazinout 08-28-2007 02:16 PM
no not hard and its pretty easy and it works for a 305
chevyrules 08-28-2007 07:13 PM
I have a K&N FIPK on my truck. Somewheres i thought i read that i can't use a TBS on mine, and i believe it as the intake tube is tight between the fan shroud and throttle body. Is it true, i cant use a TBS? Thanx, Jim
smoke20 08-28-2007 09:21 PM
If you have electric fans you are good, if not, you will have to trim on the tube a little
72charger 08-28-2007 09:26 PM
What year truck do you have? I put a throttle body spacer on my 03 Sierra. True you should trim the fan shroud but you can squeeze the intake back on. It's REAL tight but it'll work. I really need to take mine back apart and trim the shroud but I just haven't had the time. Don't let that diswade you though because it's a very good mod for the money.
03missouridirt 08-28-2007 10:44 PM
Thanks for the update. I've been looking into one of these.Affordably pricedincrease for my budget...
72charger 08-29-2007 06:13 AM
Yep. Go with the Trans Dapt Torque Curve.
prodilogical son 08-29-2007 10:25 AM
i got the trans dapt spacer for my 4.3 silverado and i was disappointed.... i opened it up and it didnt have all the parts that the instructions said that u needed> i was missing a few bolts and the spacers that go under the throttle linkage bracket... i had to go looking for that stuff andeventually found what i needed so ill let u guysknowhow well the 4.3 performs with the spacer on later
