Tire Rub
Old Apr 21, 2008 | 03:28 AM
BigTexasChevy's Avatar
Default Tire Rub
Hey guys i got a question. Ok i put a 3" TRUXXX lift on the truck, and want to go from 285/70 to 305/70......anyone know if this will rub, or am i good? i am buying new tires, and want to know what size to get.
Old Apr 21, 2008 | 08:31 AM
legacy's Avatar
Default RE: Tire Rub
With a 3 inch body lift, i think you would be fine. I could fit 285's on my truck without much problem so you should be fine
Old Apr 21, 2008 | 09:01 AM
hunt4game29's Avatar
Hey bigtexaschevy i see you are back. You and scchevylover still at the same base?Or are you back in texas?
Now for your question i just but a 3 inch body lift on my 05 and the 285 fit fine and you should be fine on the 305.
Old Apr 21, 2008 | 11:25 PM
tx_cowboy911's Avatar
My roomate has an 06 Z71 and he has 285/70s on it at stock height, I think the 305s will work height wise but its front to back when your turning that may rub a little. Just have em put one on and check it real quick and if it works have em mount the rest!
Old Apr 22, 2008 | 06:37 AM
moose's Avatar
I had a leveling kit put on and was told 305s would be close, but would fit A 3 inch lift should easily accommodate 305s.
Old Apr 22, 2008 | 10:59 AM
white_noyez's Avatar
I just did the 3 inch tortion key lift as welland i have 33's 12.50's on the way which are about the same size and ill let you know if theres any rubbing. i have been told its alright, maybe have to cut a little of the air damn but should be fine other than that but ill keep yea posted.
Old Apr 25, 2008 | 09:56 PM
91CHEVYSILVERADO355's Avatar
17 " tires?? well a 305 70 17 i dont thinkthey make.. but a 305 70 16 is abouta 33 so 285 are 31's so with a 3 inch youll be fine the only thing that is a concern is the turning it might rub a bit there
Old Apr 28, 2008 | 07:47 AM
(QUOTE)Hey bigtexaschevy i see you are back. You and scchevylover still at the same base?Or are you back in texas? (QUOTE)
Hey hunt! yah im back on here..been away for a while ya know. As for SCchevyLover AKA Mark...well he is now a firefighter, and moved back to SC....to Shaw AFB.. im still here in wyoming for another year and a half...then im going on back to texas. hows things been for you??
Old Apr 28, 2008 | 11:11 AM
chevy112488's Avatar
a 3" leveling kit allowed my buddies z71 to clear 305 70's so you should be good to go
skoot61
21
Mar 15, 2013 08:29 AM
GMC Jones
Mar 16, 2012 11:27 AM
JackMax
Feb 24, 2011 09:41 PM
daves963
44
Feb 22, 2011 07:20 AM
PostRelease
Oct 8, 2010 03:01 PM
