-   -   Tire Size Question (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/tire-size-question-15892/)
Guybo Feb 20, 2011 08:06 PM
Tire Size Question
Hi,
I have an 05 Silverado Z71 standard cab with 17" rims and 285/70R17 tires on it. What is the biggest tire that i can put on this truck without having to lift it? Thank You! Mike
honestblades Feb 21, 2011 11:27 AM
Your probabally going to have to bust out the 'ole measuring tape. There are a number of factors to figure in including the offset of the rims. That will determine how wide the tires can be. I will tell you this though..... Chevy transmissions don't like big heavy tires. You need to measure the clearance that you have in the fenderwells. The second number in the tire size indicates the height of it. Ex. 285 (width) 75 (height) -17 (rim diameter) When your measuring, make sure to take a measurement with the tires turned to the left,and the right.
