-   -   Tires (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/tires-11555/)
Dillard88 Sep 30, 2009 01:50 PM
Tires
I have a 04 Z71 not lifted and found some tires from Nitto 305/70R17 that I like. Will these fit without rubbing???
bad2006z71 Sep 30, 2009 02:30 PM
They will fit with stock 17" wheels, but will be tight. esp. if the front end is stock height.
i have aftermarket keys and 295/70/17, and i wouldnt want to go bigger.
http://i332.photobucket.com/albums/m...1/DSC03367.jpg
http://i332.photobucket.com/albums/m...1/DSC03369.jpg
http://i332.photobucket.com/albums/m...1/DSC03370.jpg
gpet6669 Sep 30, 2009 03:08 PM
I would get a set of keys or a leveling kit. Then they should fit with a little bit of trimming. Then you would need to be carfull when turning and braking or they will rub.
They will end up being 33.81"x 12.00" R17. (Just for those guys that are curious about the actual height)
Dillard88 Oct 1, 2009 07:46 AM
Thanks guys! Don't want to sound like a rookie, but what and where are the leveling keys and where can I get some??
bad2006z71 Oct 1, 2009 07:48 AM
ebay, type in chevy leveling kit. you will find a ton of keys there.
gpet6669 Oct 2, 2009 12:26 PM
Or you can go to any off road shop and they will probably have a leveling kit there for your truck, or at least a set of keys.
If you go too high with the keys then I would recommend getting a new longer set of shocks.
redbone Oct 5, 2009 08:14 AM
stock i guarantee it will rub. you could go with a bigger key and get about 2 inches of lift. but your shocks will be very tight. and the ride will be rough. is there a good deal on these tires though?
timber74wolf Oct 5, 2009 07:41 PM
I heard some one said if you were changing keys on your Chevy then buy Keys for a Ford Ranger and they work better? Anyone ever heard of this?
bad2006z71 Oct 6, 2009 07:28 AM
ford f150 keys do the same as an aftermarket key. go to ebay and buy the cheapest one that looks like oem quality, they all do the same thing.
