Torque Converter!!
Old Nov 5, 2007 | 11:36 PM
blu82chev's Avatar
Default Torque Converter!!
I am looking into a better torque converter for the ole girl and was wondering if anyone has done this, and what kind of project is it to install one. Probably looking for 2000 stall I believe. Also does the b+m shift kit help a bit? Also finnally would it be a project or could it even be possible to install a b+m floor shifter for an 06?
Old Nov 6, 2007 | 01:10 AM
Tweaker's Avatar
Default RE: Torque Converter!!
Ive seen guys use the B&M shift kit along with new corvette servos to get a much better shift (plus you can remove abit more torque management vs stock if you had a programmer) so Id definitely recommend grabbing them for around $20-45 depending where you look. Sorry couldnt exactly answer the whole thing.
Old Nov 6, 2007 | 05:35 PM
smoke20's Avatar
If you are looking for off the line power, you may want one higher than that, maybe in the 24-2600 range. I notice my truck really comes live at @ 2500 rpm.
Old Nov 6, 2007 | 08:37 PM
Cracker's Avatar
Do a run on a dyno to find your peak torque....get a converter ~500 RPM lower. You should be able to maintain street ability and achieve what you are looking for race wise. I assume you enjoy straight roads with light trees...er....stop lights.
Old Nov 6, 2007 | 08:40 PM
Cracker's Avatar
I put a Corvette stall on the 700R4 in my Toyolet. It has a 305 with a mild RV cam. It made a difference.
Old Nov 6, 2007 | 11:33 PM
blu82chev's Avatar
So does anyone know what kind of work it is to replace the torque converter or installing the shift kit? Smoke you are right around 24 2500rpm's is where I would like to be.
Old Nov 7, 2007 | 07:26 AM
jcbst12's Avatar
Just FYI. If you use a aftermarket torque converter, shift kit and a bigger tranny cooler (if needed) on your 06 you can eliminate the TQ Management all together without killing it.
Old Nov 7, 2007 | 09:30 AM
Cracker's Avatar
I've never installed a shift kit and all the torque converters I've changed came from running drivelines, they already had fluid in them. Changing them was not hard, just R/R after separating the tranny from the engine.
Old Nov 12, 2007 | 09:34 PM
thomas's Avatar
i swapped my converter when i pulled my engine. idk how hard it is with out pulling the engineor trannytho. i have a 2800 rpm converter with a pretty mild cam.
Old Nov 12, 2007 | 09:46 PM
chevy112488's Avatar
what exactly does a torque converter do?
