-   -   Tps ses p0122 p0121 p0108 p0306 (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/tps-ses-p0122-p0121-p0108-p0306-9262/)
mic_in_chevy Feb 28, 2009 07:45 AM
silverado 99 4.3L 5sp 2wd ext cab
ended up replacing my TPS, which seems to have solved the issues. When removing the original TPS, about a teaspoon of oil dripped out of the recess in which it mounts. Is the presence of oil normal?
longer version: the symptoms were rapid onset of pinging going up interstate hills and the service engine soon SES light coming on. The codes were P0122 P0108 P0306. Spark plug #6 was in fine condition visually, all plugs were replaced about a year ago. I had the codes erased, but P0122 came back immediately. Next I unplugged the TPS and droe a couple miles, but did not notice any difference. After replacing the TPS, all codes erased. SES has not lit now in about 400 miles.
496Burb May 15, 2009 01:32 AM
did the problem go away?
From what I've read about the newer computers if you reset them then it takes a good 400 miles to recompute all of the issues. Given your post date now should be a good time to determine if that had fixed the problem.
mic_in_chevy May 16, 2009 11:00 AM
thanks for the follow up .... the SES light has not lit up again. also, several weeks after replacing the TPS, i bit the bullet and replaced the lower intake manifold gaskets, which put an end to the coolant loss.
there is another long standing issue that i am ready to tackle ... i'll put it in another post
