-   -   trans or torque converter? (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/trans-torque-converter-9576/)
codys Mar 29, 2009 10:59 PM
the other day i was drivin my truck and it seemed like when it went to shift it would jump up about 500 RPM's before it shifted into the next gear...once in gear it drove ok...i was driving it the other night and comin up a steep hill and i started hearin a thumpin noise and viberation through the floorboard....now between 1500 and 2500 it likes to rev up.....what do yall think?
chrisbmo2000 Mar 29, 2009 11:28 PM
sounds like its time for a rebuild......its probably a combo of both tranny a nd convertor
codys Mar 30, 2009 12:36 AM
thats what i was afraid of......this truck is gettin expensive...200 last week now this
DamnYankee Mar 30, 2009 09:42 AM
Converter is probably fine...you probably lost your 3-4 clutch pack and your band.
chrisbmo2000 Mar 30, 2009 10:25 AM
Which would result in AT LEAST a convertor drain and cleaning but most places are going to push a new convertor (probably a hd version)
codys Mar 30, 2009 10:41 AM
would i be better off gettin a new converter or would it prolly be ok to just drain and clean this one? i dont wanna spend any more than absolutely necessary right now...moneys kinna tight
chrisbmo2000 Mar 30, 2009 11:29 AM
I would spring for a new one and get the HD version if you can. not replacing the TC would be like cleaning a fuel filter intead of replacing it. if you do just clean this one I would have it checked out first but convertors are not that expensive it would be well worth the investment then it all has a warrenty. some tranny manufacturers will not warrenty a tranny unless you replace the convertor also.
DamnYankee Mar 30, 2009 12:28 PM
There are guys running twice the hp you make through stock converters with no issues. So if it were me, I would do a flush since you said money is tight and you only want to do what is absolutely necessary. My two cents.
