Transfer Case ATF refill
3 Attachment(s)
OK...SO I know it sounds pretty straightforward but for a newbie I want to make sure I get the visual first.
Where is the drain hole and where is the fill plug? |
What year is the truck???? the drain should be just below the fill....its either gonna be an allen wrench type plug or a 22mm plug (pretty sure on the 22mm size) depends on the year
Yeah it depends on the year. You will see 2 plugs, obviously the one on top is for fill.
