Transmission Issues
Old Sep 2, 2017 | 06:16 AM
RHEC's Avatar
Default Transmission Issues
I know this topic is exhausted
1996 GMC Sierra, 4x4, 1500, 4l60e
so, I used this forum to find out my 3 and 4 clutch's and drum were trashed, I junk yarded one with just over 100k on it and I hit 5k since, had a log pop out a tranny line and lost about 4 qt in 5miles before I noticed the slip and stopped. I popped it back in and topped it off, worked great the rest of the day and night, the next day, no 3rd or 4th, come to find out at about 4200 rpms in second and let off it'll shift to 3rd and it's so hard it'll break the tires loose on gravel, otherwise 3rd feels like neutral like the last tranny, :236k, so my question is, why does this feel and act different but I'm being told it just the clutches again. Why does 3rd feel like it holds good when it hits? I'm new to the 4l60e and trying to check my options before I start throwing $$$$ at it.
Old Sep 3, 2017 | 09:58 PM
NullHead's Avatar
Your valve body decides when to send fluid into the clutches to make them apply. When it does so, there is a delay because fluid must fill an accumulator cavity first. when fluid fills the accumulator, fluid pressures pushes on the piston which squishes your clutches and they engage. If your clutches are worn out, the clearance inside your clutch pack gets bigger and takes longer for fluid to build and make the clutches engage.
So bad clutches don't always cause your 3rd of 4th gear to be completely inop, they can cause a long shift too. Time for a rebuild.
Old Jun 27, 2018 | 08:40 AM
Kondor1500's Avatar
Hey don't mean to steal your post with my questions lol but I can't figure out how to make my own, I have a 2001 Chevy 1500 and when I'm cruising between 80-90k it seems to be shifting back and forth between gears also does it when I'm going slower just doesn't seem to wanna pick a gear and stay in it I've changed filter and fluid no help just wondering if it could be a electrical issue or is my tranny on it was out the door
boomer_05sierra_sooner
Jul 1, 2014 05:12 PM
In2Trux
Jan 25, 2012 03:23 PM
hammer down
Nov 11, 2011 06:47 AM
theduck007
Oct 8, 2008 08:51 AM
sknaffl
18
Dec 3, 2007 03:54 PM
