Transmission randomly goes into neutral while driving
Old Oct 21, 2022 | 01:15 AM
Randy1983's Avatar
Default Transmission randomly goes into neutral while driving
Hi I have a 2009 Silverado 1500 5.3 truck that has some transmission issues. Sometimes my truck will go into neutral after taking off from a stopped position and I have to stop in the road and put it into park then back into drive again and it's fine it takes off no problem. Only done it a few times in the past several months. Also had the transmission go into 4wd by itself once. The **** was still set to 2wd when it went in 4×4. Had to pull over off road and turn **** into 4wd hi then back to 2wd to get 4wd to disengage. Any ideas what is wrong? Hoping someone knows what this could be? Transmission fluid was fine.
Old Dec 2, 2022 | 06:00 PM
Boreal's Avatar
How many miles on the truck, what transmission, and what tcase? Are you sure it's the tranny going into neutral? The transfer case could also have neutral and if the actuator is going out, it could be shifting inadvertently. Or what can also happen is bearings in the tcase go out and the slop allows inadvertent shifting. I had one shift into 4lo while driving at 60 mph, blew the planetary to pieces.
KJAC
Jun 26, 2011 10:40 AM
JasoNeon
Sep 25, 2010 07:42 PM
big_ladainian
Nov 10, 2009 01:59 PM
kkcolt4
Dec 18, 2008 04:41 AM
jimfgsm
Jul 10, 2007 06:03 PM
