-   -   Transmission slipping out of 4th (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/transmission-slipping-out-4th-1857/)
cwdunwoody Oct 23, 2006 12:06 AM
I have a 90 Silverado with a 350 5sp. Whever I pu it into 4th, it pops out of gear. Does this mean the synchro for that gear is bad? Does this mean the transmission might be on its last leg? If I pull the transmission out can just that synchro be replaced without too much effort?
bignn Oct 27, 2006 07:37 AM
RE: Transmission slipping out of 4th
manual trans are easy to work on if you pull it a part you will be able to see wht the problem is
