Trouble code
Hey Bebop do you still have your DTC sheet with yoour programmer? I keep getting the low coolant light once engine temp gets over 160deg's. If I get the code would you be able to let me know?
RE: Trouble code
Let me know what code you get and I can tell you
RE: Trouble code
Cool will do, and also the coolant level is fine too.
RE: Trouble code
Well programmer says no DTC's exist. So my truck is saying no fault, the coolant level is fine but I still get a low coolant light past 160 deg.
RE: Trouble code
that won't set a code,the sensor in the jug must be faulty
