Truck sitting low on drivers side
:eek: Does any one know what would cause my 94 silverado to be lower on drivers side than the other side ??????
Could be a few things...
Bad Coil Spring Bad Leaf Spring Worn Body Mount Bushings Tweaked Frame Torsion Keys out of adjustment - 4WD Hope that helps! |
I have heard of the driver side front coil spring to have weaken and sag on that side. There is a new coil spring that will level it out. I seen it on the Advance Auto website. Mine was like that 2. But, if your gonna go that route in replacing them, just order a set of some good springs like Beltech or Ground Force. Not to lower but to install better springs.
my 89 does it when i fill up the gas tank.
