truck weight
Can anyone tell me how much a 2008 Silverado crew cab with a standard bed, two wheel drive,and diesel engine weigh?
Thanks |
RE: truck weight
on the driverside door jamb it says your gvwr or the weight of the truck
RE: truck weight
Thank you.
RE: truck weight
Ok guys. The GVWR on the post says 9200 lbs. There is no way the truck weighs 9200 lbs. The GVWR is the truck with people gear etc. Anyone know what just the truck weights?
RE: truck weight
The local dump in my area will let you wiegh your vehicle on the truck scale....sometimes it's free, sometimes $5. Do you have anything similar in your area?
RE: truck weight
Truck stops also have scales
RE: truck weight
You can also google it, found mine.
| All times are GMT -5. The time now is 08:44 AM. |
