Truck won't start
I have a 96 silverado, ran fine yesterday, today won't start. Battery is charged, all power stuff works (lights, radio, horn, etc) but the starter will not turn. So naturally I thought the starter needed to be replaced. So I did that, but still no luck. Its like there is no juice getting to the starter. All connections are good. No blown fuses that I can see. What could it be???
RE: Truck won't start
It could be anything.....if you said that all your power accessories were working its not a problem with the electrical system. Are you getting anyting when you turn the key?
No, I was not getting any juice at the starter, nothing.
However, I finally figured it out. Turns out that a disabled, aftermarket security system that was installed by the previous owner had shorted and blown the starter fuse. Every time I replaced the fuse and turned the key, the fuse would blow. So I yanked out the security system and replaced the fuse again and everthing worked normally. What a pain. I'm all good now. |
| All times are GMT -5. The time now is 05:30 AM. |
