Truck wont start
I finally got finished putting the new motor with all the accessories and everything. went to start it wont start. Battery is good. i got the starter connections good. I cant think of any other reason. It doesnt even click over
RE: Truck wont start
Ignition swich? The interior lights coming on? Battery grounded correctly?
no the interior lights are not comming on which is weird but the heat works and front headlights
Tailights work? Horn? Turnsignals?
It might be as simple as a bad or misplaced wire. What kind/make/size/year of engine? |
could be a bad ground somewhere...
1992 silverado with a 350 ya turn sighnals work i just got the poweer windows and power locks to work wipers work to and so do rear lights everything except cabin lights
If you get nothing on tunring the key, and you are sure the starter is hooked up correctly, check the main ground. Do the idoit lights come on when you turn the key? Sorry for all the questions but I am a little lost on exactly what it could be.
yes check engine and everything. Also when i turn on my headlights my windshield wipers come on at the same time and if i turn the lights off they turn off to which is really unusuall
There is definately a wire crossed somewhere. I would track down that problem with thelights first. You might find the problem there be it a crossed wire, shared ground or something along those lines. I HAS to be electrical and I am willing to bet its between the ignition switch and the main fuse box. Argon will prob be of more help here.
Yes i got it. It was a loose ground thanks for the help guys
| All times are GMT -5. The time now is 10:30 AM. |
