-   -   turn signal lever (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/turn-signal-lever-9122/)
ahealthydistrust Feb 10, 2009 12:59 PM
turn signal lever
I broke off my turn signal lever (bad anger management skill) and need to replace it. I have been searching the internet but have had no luck. Any suggestions?
2007 Silverado Vortec Max
Is it hard to replace?
Part number or actual name for the part
dmccartyfan Feb 10, 2009 06:21 PM
RE: turn signal lever
Not sure about your year/model, but if the lever pulled out from inside after breaking, it's probably gonna need the turn signal cam. To get to it, you'll need to pull the steering wheel - but MOST IMPORTANTLY, I'm sure there are charges for the airbag inside and I for one would not want to tear into it myself. Far too dangerous and/or costly if done incorrectly.
Just my opinion. Not for rookies.
chrisbmo2000 Feb 10, 2009 07:39 PM
my guess is that your turn signal lever is all one piece ( turn signal-4ways-wipers-dimmer-cruise).....you better dig deap into your pockets because it WONT be cheap and being a 07 you are dealer bound for the part.....changing takes moderate skill........air bags are not a worry there is a procedure for "disarming" them but I dont think you have to pull the wheel for this one.....it bolts to the side
dmccartyfan Feb 10, 2009 07:49 PM
Thanks for the correction, Chris - I'm used to the old days :)
chrisbmo2000 Feb 10, 2009 08:17 PM
no problem Tom I had to think about it for a sec also
dmccartyfan Feb 10, 2009 10:57 PM
I think we can ALL learn something from this... NEVER break your OWN stuff :)
