Useful Specs
Here you go:
RECOMMENDED FLUIDS AND LUBRICANTS Engine Oil - API "Certified For Gasoline Engines" Viscosity - 5W-30 Recommended, 10W-30 Okay if 5W-30 Unavail. Fuel - Unleaded Gasoline - 87 Octance Minimum Automatic Transmission Fluid - DEXRON III Automatic Transmission Fluid Automatic Transfer Case New Venture 236 NP8, New Venture 246-NP8 - GM Auto Trak II Transfer Case Fluid Borg Warner 4481-NR3, Borg Warner 4482-NR4, New Venture 149-NP, New Venture 149-NP3, New Venture 263-NP1, New Venture 261-NP2 - DEXRON III Automatic Transmission Fluid Differential Front Selectable 4WD - SAE 80W-90 Gl-5 Gear Oil Full Time 4WD - SAE 75W-90 Synthetic Gear Oil Rear - SAE 75W-90 Synthetic Gear Oil Quadrasteer Rear Axle - GM Synthetic Axle Lubricant Power Steering Fluid - GM Power Steering Fluid Brake Hydraulic Fluid - DOT 3 Brake Fluid Engine Coolant - 50/50 Mix of DEX-COOL Coolant and Demineralized Water Parking Brake Mechanism Grease - White Lithium-Based Grease NLGI no.2 Chassis Lubrication Grease - NLGI Grade 2 or GC-LB Chassis Grease Hood, Door, Trunk Hinge Lubricant - Lubriplate, lubricant aerosol spray Door Hinge and Check Spring Grease - NLGI no.2 Multi-Purpose or Equivalent Key Lock Cylinder Lubricant - Graphite Spray Hood Latch Assembly Lubricant - NLGI no.2 Multi-Purpose or Equivalent Door Latch Lubricant - NLGI no.2 Multi-Purpose or Equivalent CAPACITIES Engine Oil (inlcuding filter) V8 - 6.0 Quarts Manual Transmission New Venture 3500 - 2.2 Quarts New Venture 4500 - 4.0 Quarts ZF S6-650 - 6.3 Quarts Automatic Transmission Fluid and Filter Change 4L60-E/4L65-E - 5.0 Quarts 4L80-E/4L85-E - 7.7 Quarts From Dry, Including Torque Converter 4L60-E/4L65-E - 11.2 Quarts 4L80-E/4L85-E - 13.5 Quarts Transfer Case New Venture 246-NP8 1999-2001 - 2.4 Quarts 2002 & Later - 2.0 Quarts New Venture 149-NP - 2.0 Quarts New Venture 263-NP1 - 2.4 Quarts New Venture 149-NP3 - 2.0 Quarts New Venture 261-NP2 1999-2001 - 2.3 Quarts 2002 & Later - 2.0 Quarts Borg Warner 4481-NR3 - 1.5 Quarts Borg Warner 4482-NR4 - 1.5 Quarts Cooling System V8 Engine 4.8L and 5.3L - 16.7 Quarts 6.0L Yukon Denali, Yukon XL Denali - 19.0 Quarts All Others - 16.8 Quarts BRAKES Disc Brake Pad Wear Limit - 3/32 Inch Drum Brake Shoe Wear Limit - 1/16 Inch Parking Brake Shoe Wear Limit - 1/16 Inch IGNITION SYSTEM Spark Plug Type 1999 V6 - AC Delco 41-932 or Equivalent V8 - AC Delco 41-952 or Equivalent 2000 V6 - AC Delco 41-932 or Equivalent V8 - AC Delco 41-952 or Equivalent 2001 V6 - AC Delco 41-932 or Equivalent V8 - NGK PZTR-5A15 or Equivalent 2002 V6 - AC Delco 41-932 or Equivalent V8 - NGK PZTR-5A15 or Equivalent 2003 V6 - AC Delco 41-932 or Equivalent V8 - AC Delco 41-974 or Equivalent 2004 & Later V6 - AC Delco 41-932 or Equivalent V8 - AC Delco 41-985 or Equivalent Spark Plug Gap V6 Engine - 0.060 Inch V8 Engine 1999-2003 - 0.060 Inch 2004 & Later - 0.040 Inch Firing Order V6 Engine - 1-6-5-4-3-2 V8 Engine - 1-8-7-2-6-5-4-3 |
