Valve seals
So I pulled the valve covers off earlier and ran a wire down the returns to make sure they were clear. Couldn't really tell if they were stopped up or not. Still smoking as if now. Going to do a compression test fri and hopefully rule out the rings. Will keep you posted. Thanks for the help guys. Hope to get this figured out!
Please let us know.
So I just got done checking the compression.
Cyl 1= 125 Cyl 2= 125 Cyl 3= 130 Cyl 4= 115 Cyl 5= 125 Cyl 6= 115 Cyl 7= 125 Cyl 8= 115 Any thoughts???!!! |
Those numbers seem pretty low, I think you should at least be around 195 but I could be wrong but Ill let someone else chime in.
| All times are GMT -5. The time now is 07:38 AM. |
