Washer Fluid Problem
I recently put a 3" lift on my 2006 Silverado with 32" tires and i rub just a lil when turning very sharply...i'm going to cut a little bit of the splash guard in the wheel well but one of the other problems is that my washer fluid container is one of the things that is rubbing...anyone else had this problem? How could i make the washer fluid container smaller? Do they make a shorter container? Could i cut it smaller and then patch it or something? Thanks...
You could move it to the other side of the coolant resorvior.
^^^ is that a difficult process? Drilling holes? Would it create another problem?
ok so i completely removed the washer fluid container...and no rubbin which i'm stoaked about but now i dont have washer fluid to use...what should i do? How would i move it to the other side of the coolant resevoir?
very simple just reroute your electrical and "plumbing". I dont remember what the under hood looks like on an 06 but it should be real easy......I think you are thinking way too hard about it :) just find a spot where it fits and put it there.
