-   -   What is the 2007 Chevy Silverado 20" rims backspacing? (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/what-2007-chevy-silverado-20%22-rims-backspacing-6130/)
bearcat6006 Feb 6, 2008 10:23 PM
Does any one know the backspacing on 2007 Chevy Silverado 20" factory rims. I was wanting to put on new rims an I was trying to get close to the factory backspacing with them.
seb37 Feb 6, 2008 10:24 PM
RE: What is the 2007 Chevy Silverado 20" rims backspacing?
I am pretty sure it is 4.5
bearcat6006 Feb 6, 2008 10:51 PM
I don't think so because they are a 8.5" wide wheel not a 7.5" like the 17" wheels.
seb37 Feb 6, 2008 10:57 PM
I can tell you how to measure it if you like
stopspazinout Feb 6, 2008 11:06 PM
your better off getting a tape measure and checking it out yourself seeing as 20 in rim stock is a rare option.
bearcat6006 Feb 6, 2008 11:27 PM
how do you measure the backspacing.
seb37 Feb 6, 2008 11:33 PM
It is the distance from the rear of the rim to the mounting surface. If you take your wheel off and lay it face up and drop a ruler through the center hole to the ground and measure should get you pretty close
04blkextcab Dec 4, 2008 11:03 PM
The proper offset or backspacing for a new gm is +30mm for 07 and 08, for 88 to 2006 and 2007 classic it is +18mm, wheels 07 and 08 will sit under the wells of older style and Older +18mm wheels will stick out slightly on new model trucks
