View Poll Results: A poll
doug thorley
75.00%
jba
25.00%
magnaflow
0%
edelbrock
0%
dynamax
0%
Voters: 4. You may not vote on this poll
what long pipe should i get
Old Oct 25, 2007 | 06:33 PM
  #11
seb37's Avatar
Default RE: what long pipe should i get
Ok, i was wrong on the Hooker Headers. They do offer a long tube, but once again they are 1 3/4 primary tubes and generally long tubes are better for low end, but not in a 1 3/4 primary. Spoke to the folks over at Dynatech and they agreed that on their headers, which are also 1 3/4 tubes you are not going to see a gain in the low end, especially in a stock application. They would work best in a highly modified or a supercharged application.
Old Oct 25, 2007 | 08:46 PM
  #12
Cracker's Avatar
Are they leaking around the flange or between the flange and pipe? Get some stainless lock washers to keep the bolts from backing out.
Hooker coats inside and out but if you bang them with a tool they will scatch through the ceramic and you'll get a rust spot. Granted, you have to bang them pretty hard....try working on a small block chevy in a lowered '87 2wd toyota.
Old Oct 25, 2007 | 09:02 PM
  #13
seb37's Avatar
You can also try soaking the gasket in water first and then let them dry before installing. That way they have already expanded and contracted.
Old Oct 25, 2007 | 09:23 PM
  #14
smoke20's Avatar
I have the edlebrock ceramic coated in charleston, SC and have had no issues. They look brand new except for the lock washers (they are having heat issues so I plan to replace them with better ones) and have been on for 11 months.
Old Oct 25, 2007 | 11:50 PM
  #15
Grey Ghost's Avatar
http://www.stans-headers.com/
Get the Tri-Y's preserve your low end.
Old Oct 26, 2007 | 12:18 PM
  #16
thomas's Avatar
i went through three sets of gaskets trying to get the leak to stop, and now i have the Mr Gasket copper ones. i bought new header bolts and they are all tight, so ill just have to pull them off again.
Old Oct 26, 2007 | 03:22 PM
  #17
seb37's Avatar
Are you using the locking header bolts, like a Stage 8? Also Percy's make's a dead soft alum gasket that seems to work rather good
ryobi
9
Nov 18, 2010 10:08 PM
kota123
May 27, 2009 05:28 PM
popo
16
Feb 28, 2008 10:08 PM
chevy112488
8
Dec 30, 2007 02:28 PM
rooster18
Aug 31, 2006 04:40 AM
