Jegs also had a bolt on setup you could order. An old boss of mine had an 85 el camino with a 305 4 speed. We put the Jegs setup on it and it was a blast of a little car. Nothing insane but a real kick in the pants.
Originally Posted by NullHead
(Post 71292)
Which kit might this be?
I'll end up having two 305SBCs on my hands ... I'm thinking toy around with one before I go to swapping the whole thing. |
(Post 71240)
Personally, the easiest thing to do would be to get a 350 vortec engine from a salvage yard and build it up a little. A high flow exhaust will also help. As far as the drivetrain, I wouldn't mess with it as long as the tranny's still shifting smooth. You might benefit from differential cap with fins on it ... like any of these: Search Results for differential cap - SummitRacing.com
I honestly don't know anything about hot rodding drivetrains, but perhaps a transmission cooler would help keep the tranny healthy while you "hot-dogg" it ;) Make sure your U-joints are good too. |
It would keep the diff fluid cooler than a regular fin-less one. I assume the fins on the cap would help dissipate heat. And I don't imagine axle seals like to be hot. Or the gears that the fluid lubricates. I don't have any backing material to support this, but it's just a thought anyways.
