-   -   Wheels on 06 Z71 (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/wheels-06-z71-10736/)
jhare5815 Jul 22, 2009 08:53 AM
Wheels on 06 Z71
I've got a stock '06 Z71 crew cab. Time for some new tires and was wondering the largest I could go without any rubbing? Can I do a +1 size with all-terrain tires?
Currently stock 265/70/17.
BTW, it's a 1500.
bad2006z71 Jul 22, 2009 11:46 AM
285/70/17 on stock wheels as is
295/70/17 on stock wheels with a leveling kit
jhare5815 Jul 30, 2009 07:50 AM
Thanks for the info. I'm afraid this is where my question becomes a little more technical...
I've decided to install a 2.5" ReadyLift leveling kit, drop down to a 16x8 rim and go with a 33x11.5 (285/75/16) tires.
The ReadyLift fitment guide says a wheel with a 5" backspace (on 8" rim) should be used. The three rims I am looking at have a 4", 4.26", and 4.5" backspace.
Does anyone know if I will run into a rubbing issue with any of these and if so, how much? Slight rubbing at full turn on inner fender well is acceptable. In fact, my stock '01 Ranger Off Road had this problem off the lot.
Also, without me pulling the wheel to measure, does anyone know the backspace on the stock Z71 wheel?
bad2006z71 Jul 30, 2009 10:35 AM
not sure on the backspacing, little technical for my head. But you will not be able to run 16" wheels on an 06. they made the brakes larger, so thats why they went to 17" wheels. you would have to grind down your front calipers alot to get them to clear a 16" wheel
jhare5815 Nov 4, 2009 08:52 AM
P vs LT tires
Excellent advice. Never thought about the brake size.
I installed the torsion keys and it did effect the ride quality (even at 1.75") even though mfgr. said it wouldn't. Anyway, staying with stock rims and will go with the 285s.
Can any one tell me the difference between P-metric and LT-metric tires? It seems anything over 265 only comes LT. I ordered a set of LT285 BFGs but then the shop said they wouldn't install them on my truck since it has P265s. I guess some liability issues.
Am I stuck with a stock tire size? Is there a safety factor involved?
bad2006z71 Nov 4, 2009 11:00 AM
P=passenger
LT=Light Truck
do not go with a p series on a truck. they arent designed for loads. go with a load range C or D in an LT series tire.
The shop is retarded. go to another one. they probably are just pissed you didnt buy the tires from them. my local tire shop installed my 295/70/17's on stock alloys without issue
tiggermane44 Feb 1, 2012 08:46 PM
i have an 06 silverado too butim also 17 and i dont have enough money for a lift i want 35's with my 17 inch rim but everybody is telling me to get 33's and save up for the lift but whats the point if i can buy the leveling kit now please respond
