whining noise
whats up guys i got a new noise thats buggin me. Whenever i hit the gas it makes a whining noise much like a bad power steering pump would. I though maybe it could be my power steering but it doesnt do it when im turning. Could it be the power steering? if not than any other idea what it could be? any feed back would be much ablidged.
Well.....is the power steering fluid full? How about the Transmission fluid? the alternator or the water pump? Can you pinpoint the sound when you open the hood?
Time for either the stethoscope or the old long 1/2" extension in hand and ear tool!
i got the same one i think. i replaced my alternator water pump and have tried about everything. its hard ton pinpoint. almost sounds like its the ac pump for me
Does it only do it when driving or in park as well?
both and it sucks cuz you cant make a truck sound big and bad with that noise always going off
I would pull the belt off and start it up to see if the noise goes away. Don't let it run for a long time b/c you won't have any fan or water pump.
Spray each pulley with a squirt of WD40. When it goes away you might have found it. Just my 2 cents.
What he said. I've got a spinning noise that happens from time to time on my truck. Whenever I hear it I immediately grab the WD-40 and soak down everything including the belt. It'll go away for 3-4 months. I think mine is a spun alternator bearing though.
guys same thing happened to me. it's your ac bearing mostly and it's a bitch to replace.
| All times are GMT -5. The time now is 04:49 AM. |
