window adjustments
Old Jul 10, 2005 | 08:28 PM
fearless_fb's Avatar
Default window adjustments
I have a '93 gmc 1500. The passenger window doesn't go up on it's own. I've heard it's just an adjustment but I can't figure out how to adjust it. It goes a few inches up, and then the front end of the window will stop, the back will keep going a little bit, it'll get crooked and then stop completely. The only way to get it up is to put upward pressure on the font of the window. Any idea will help, thanks.
Steve
Old Jul 11, 2005 | 03:57 AM
Makaveli187's Avatar
Default RE: window adjustments
check to make sure there is not a broken window guide
Old Jul 11, 2005 | 02:35 PM
Patrick's Avatar
im not sure, but many newer vehicles have a sort of track which guide the glass up and down, and it can come out of that guide. does the door panel appear to be easily removable?
Old Jul 11, 2005 | 09:15 PM
The door is very easily removable, I had the cover off once, and underneath is a black metal sheet that the window motor mounts to that is also removable, the track mount bolts are accesible at this point or adjustment bolts, but I can't figure out how to move the track or if it's even possible.
Steve
Old Jul 12, 2005 | 04:50 PM
Thanks guys, I was muckin around with it again and I found a bend in one of the tracks, so I took the track bracing off, straightened it, put it back in and sprayed white lithium greese through it, and it works like new.
10ptman
Apr 15, 2006 12:09 AM
timbo
Mar 29, 2006 08:16 PM
KS Z71
Dec 5, 2005 08:12 AM
BADPHNX
Aug 16, 2005 02:11 AM
BADPHNX
Jan 16, 2005 06:34 PM
