Window question
Old Jun 21, 2008 | 11:41 AM
1BadZ71's Avatar
Default Window question
My right side window moves really slow in the middle section of movement, but it moves at normal speed or almost normal speed at the bottom and top sections. Do you guys think this is the motor going out, or the gear is worn? Any ideas before I tear into it would be greatly appreciated.
Thanks
Steven
Old Jun 21, 2008 | 05:51 PM
Chevycowboy's Avatar
Default RE: Window question
My drivers side does the same. Do you park your truck anywhere near a pine tree or cyprus tree? I have a pine tree next to the drive way that just litters the entire driveway with sap and pollon. I think some of the sap got in there.
Old Jun 21, 2008 | 11:07 PM
EarnhardtZ71's Avatar
My 03 is very similar. I've even had the passenger side motor replaced while it was still under warranty. That was a couple of years ago. Now they both seem to run about the same speed...normal at first, then a little slower, then normal again. I don't know the answer to the problem but I've just learned to put up with it.
Old Jun 22, 2008 | 10:58 AM
rxsteven's Avatar
Mine do it to I just roll up 1 window at a time so I dont take any power away from one or the other.
Old Jun 22, 2008 | 11:50 AM
1BadZ71's Avatar
I have no problem just dealing with it, but sometimes it will stop halfway up like the motor is going out. Someone told me it sounded like the gear wearing irregularly. The big deal is I am in the military and I have to be able to roll my window up and down when I go on base. I made a mistake before, it is my drivers side window.
Old Jun 23, 2008 | 10:20 PM
MrLM7's Avatar
My right side does it, too....
Old Jun 23, 2008 | 10:57 PM
jcormier89's Avatar
my left side used to do it...then it completely gave in, so i got the motor replaced...worked fine ever since...been about a year or so
Old Jun 24, 2008 | 08:08 AM
jcbst12's Avatar
Mine is slow on the passenger side. Sometimes reeeeeeaaaaaal slow. But I am not pulling it apart until it won't move at all. Ha ha I am so lazy.
Old Jun 24, 2008 | 09:15 AM
1BadZ71's Avatar
how hard are the door panels to remove on these trucks? also does anyone have an opinion on the window motors? new or remanufactured?
Old Jun 26, 2008 | 09:30 PM
chevybird72's Avatar
Try cleaning the run channels (where the window slides) most common cause is dirty weatherstrip which cause drag on the motor and they eventually fail. Just take a terry towel and glass cleaner and run up and down inside the groove of the run channel.
