Wireing Problem, Old School 79
Old Dec 22, 2006 | 11:24 PM
Ender's Avatar
Default Wireing Problem, Old School 79
I have the old school 79 custom deluxe 4x4 and it has a major wiring issue. It has done fine untill now, the right turn signal has fouled every thing up. The right headlight either runs very dim or not at all and the right turn signal indicator in the dash stays on when the headlights are on. I need HELP.
Old Dec 22, 2006 | 11:57 PM
HemiKiller's Avatar
Default RE: Wireing Problem, Old School 79
You probably already have but I would start with the bulbs making sure the turn signal is not burnt out then check the ground for the lights as this is the cause of most electrical problems. If nothing is found with these look over the wiring to try and find any damaged wires try to follow them to the fuse box. Hope you get the problem tracked down, let us know.
Old Dec 23, 2006 | 12:52 AM
under construction's Avatar
sounds like a ground wire or the wrong kind of bulb.
Old Jan 5, 2007 | 02:35 AM
Ender's Avatar
Thanx for the help, anymore ideas would be GREATLY appreciated.
Old Jan 7, 2007 | 02:07 AM
sc64chevy's Avatar
I have an 83 and had a problem similar after a put a flat bed on it and put different taillights on it. If you cont have any wiring or ground issues up front go to the taillights and check all of your wiring and grounds back there cause it can back feed through the system. But it definately sound like a ground issue to me to.
JoshLikesBeer
May 27, 2011 03:11 PM
dfriendly1
May 17, 2011 06:49 PM
TP5.3
17
Nov 2, 2008 01:21 AM
hippie
Feb 2, 2008 02:11 PM
makoltd
Nov 15, 2006 10:24 PM
