-   -   zero heat 92 gmc sierra (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/zero-heat-92-gmc-sierra-17918/)
nekra77 Nov 25, 2011 07:01 PM
does anyone know where the heater control valve is located in a 1992 GMC Sierra 5.7L/350 half ton?????? my truck has zero heat in the cab when the temperature is set to hot/high. has anyone had this problem??? coolant levels are full everything seems to be circulating, but the heater core takes a while to heat up. i took the heater core out and put the garden hose to it and water came shooting out the opposite opening without any leaks. please help
azjetfighter Nov 26, 2011 12:39 PM
Have you checked to make sure your heater controls/blend door are all functioning as advertised?
nekra77 Nov 27, 2011 11:17 AM
yes they are all working
