-   Commercial Trucks (https://www.truckforums.com/forum/commercial-trucks-73/)
-   -   2001 International 4700 Hydraulic brakes (https://www.truckforums.com/forum/commercial-trucks-73/2001-international-4700-hydraulic-brakes-23949/)
Caleb12321 Dec 6, 2023 05:04 PM
2001 International 4700 dt 466
hydraulic brakes
I replaced the brake pads all around. Compressed the calipers and fluid pushed out of reservoir "normal" and put back together and everything works great.
The issue I am having is the brake pressure light will come on after driving and I go to stop. Once it's on it stays on.
Everything is normal other than the light coming on. Brake motor comes on when truck is off and brakes are pressed, /when key is on and not running the brake motor runs like it should,
Any idea? I have talked to a few mechanics and one told me to pull sensor off the side of master cylinder and see if I see a rod. It looks like the rod is touching the sensor and not in the right position.
jacksondom Dec 9, 2023 03:38 AM
The 2001 International 4700 with hydraulic brakes offers reliable performance. The braking system functions well, providing effective stopping power. Overall, a solid choice for those seeking dependable brakes in a commercial vehicle.
